question:import the xer file
liu yi
User offline. Last seen 16 years 3 weeks ago. Offline
when I import the .xer to P6,only the 29o4KB file cann’t be imported.but the 2006KB’s file can be.why? the promption is :an applicantion event has been intercrepted,please note the event code for reference .event code :AVAA0-3746-4.
thanks!
Hello,
I have problem in importing xer p6 file.
Error occur "CVRCU-1939-9 Default value  provided for field ev_compute_type is not valid"
Thank you in advance for your input.
COCOY
User offline. Last seen 3 weeks 3 days ago. Offline
make sure that you have the correct java version that it is working.
Wael Abdelfattah
User offline. Last seen 7 years 50 weeks ago. Offline
I'm having the same problem. The only solution I came up with, is to start a new database with a new connection and then import all projects all over again.
