changed the WBS :locate activities with old WBS values
Pranab Kumar Deb
Hello Freinds,
I changed the WBS of a project , now some of the activities which are assigned the previous WBS codes i am unable to locate please can you advise me how i can find activities which have WBS not defined in the WBS dictionary.
deb
Pranab Kumar Deb
thanks ferdinand and oliver , that were excellent ideas.
now while in my wbs layout (with all activities filter) there are 1527 activties , where as when i sort by project i get 1531 activities , i dotn know where the 4 activities go in wbs layout.
regards
deb
Ferdinand U.
User offline. Last seen 7 years 36 weeks ago. Offline
mistake...should be --- you must NOT be in WBS layout when you filter
Ferdinand U.
Gchange if WBST eq " " then WBS eq DELETE
then filter all activities WBS eq (no value)
take note: you must be in WBS organized layout when you filter...
Steven Oliver
User offline. Last seen 12 years 25 weeks ago. Offline
In your WBS view, use a spare Activity Code field as a column, and fill this with a value.
Switch to activity view, and with the same column diplayed. Any activity which does not have an entry in the Activity Code field doesnt match the WBS ( I Think !)
