Global Change to Add the WBS name with the activity name
kumar s
User offline. Last seen 9 years 43 weeks ago. Offline
Dear All
i tried to add the WBS name  starting of each  activity which falls in that WBS.
i used the global change
where
blank....
then
activty name  =  activty name  & wbs name
by this i got the result such as
earlier- issue permit
after global change-UNIT21issue permit
now my problem is i want to have - or space between theese two like UNIT21- issue permit or UNIT21  issue permit
Please guide me
thanks in advance
Simon Willson
User offline. Last seen 4 years 11 weeks ago. Offline
Andy,
The combining of parameters in the global change function works very well.  Exporting to Excel is cheating :)
Simon
kumar s
Dear All
I got it finally..
the global change criteria is .
where
blank....
then
then again run one more global change like this
where
blank....
then
activty name  =  any user text(@,& etc)  & wbs name
now apply changes.after that go yhe replace option and replace the character with space.this complets the task
so there is no need to export and import also
hope this helps
Andy Power
User offline. Last seen 5 years 4 weeks ago. Offline
Hi Kumar
I'm not aware of a way of adding an extra parameter/value and operator to the global change, but another approach that might work is to export the project to Excel, under export type choose Activities.  Open the spreadsheet, concatenate the WBS and Activity names together ina seperate column and then paste the resulting values in to the activity name column save and import back in to Primavera?
Andy
