Import Project codes?
13 replies [Last post]
Alexandre Faulx-B...
User offline. Last seen 2 years 43 weeks ago. Offline
Hello,
my customer would like to enter all the project specs in MS-Excel, as he feels more confortable than in the relevant P3 forms.
Is it by any means possible to export/import project codes and obtain the same result as for the activity data custom items?
Alexandre
Forum Guest
User offline. Last seen 31 weeks 2 days ago. Offline
Hi there Andrew,
We have tweaked the code so that it will (hopefully) show the slash, i.e. the \\\\\\\\\ character.
Thanks for the observation.
PP Admin.
Andrew Podolny
User offline. Last seen 1 year 33 weeks ago. Offline
This forum doesn’t support slash symbol.
Andrew Podolny
Go to debug mode and check the vba code. I’m pretty sure that something wrong with project path or project name.
Be aware - you have to put short path in any Macro.
For instance:
c:progra~1 instead of c:Program files
Don’t hesitate to contact me personally.
Andrew
Rajeev Kumar
User offline. Last seen 10 years 1 week ago. Offline
Thanks. But I get an error 501111, file not found. Any ideas?
Thanks once again.
Andrew Podolny
Hi, there
Make sure P3 is already running on your computer (even with no project opened). That may help.
Rajeev Kumar
I checked the spreadsheets. For the spreadsheet to work is it necessary that p3win directory exists in the C directory or will it work even if the p3win directory exists in any other subfolder in the c: directory. It just displays exiting RA as soon as I run any macro.
Can anyone help?
Andrew Podolny
Hi, there.
All a.m. utilities you can download from here:
http://rapidshare.de/files-en/489358/P3_excel.zip.html
Andrew
Jaco Stadler
User offline. Last seen 18 years 19 weeks ago. Offline
D:SUPPORT/UTILS/EXCEL/activity
Will give you the ability to import Codes & Descriptions from xls
Jaco Stadler
D:SUPPORTUTILSEXCEL
ACTIVITY
This will allow you to export/import the Code & Description. If you jou want to assign act codes to an activities you can just export a norml wk1 file and ensure that you have ask for activity id & activity codes
Steven Oliver
User offline. Last seen 12 years 14 weeks ago. Offline
I dont recall the name of the file, but they are *.xls, with macros written to import/export activity codes, resources and WBS.
Steven Oliver
Supplied with P3 are some utilities to do exactly this. If you dont have the original CD, PM me and I’ll forward a copy.
