Import activity codes dictionary
6 replies [Last post]
Renaud Moisan
User offline. Last seen 13 years 23 weeks ago. Offline
Hi all,
I am very sorry if I am asking a question that ahs been discussed already, but it seems the search tool of the forum has been turned off temporarily.
I am looking for a way to enter/modify/import/merge (any) the activity codes dictionary.
Anybody has any hints on ways to pursue.
ruben quintal
User offline. Last seen 16 years 46 weeks ago. Offline
Can it be done in version 3.1
tnx.
Paul Harris
User offline. Last seen 1 year 32 weeks ago. Offline
Yes Primavera Version 3.1 will import codes using this spreadsheet.
Paul E Harris
www.eh.com.au
Paul Harris
Solution ID: 200252492644 on the Primavera Knowledge Base has a spread sheet that may be used without the loading of RA and is quite simple to use.
Paul E Harris
www.eh.com.au
Gün Göksu
User offline. Last seen 2 years 16 weeks ago. Offline
hello,
you can also use the activity.xls and project.xls files to retrieve and update the dictionaries.
the excel files are in the cd’s.
I understand that you still have to copy the RA files to your c though. the macros are nothing further than a frontend to the RA.
working with excel is flexible and RA filters the data while importing to P3 so that nothing very obvious messes with P3 database.
Hope this helps.
Gün Göksu
Jose Frade
User offline. Last seen 3 years 35 weeks ago. Offline
Just a small addition to what was said.
RA is the right tool to use.
When you install P3 RA is not automaticaly installed.
You have to locate it in the CD and simply copy it to the P3WIN directory in your computer/server.
Take a look in RA - it contains a lot of helpfull samples not just for the subject mentioned.
BR
JMFrade
IC Quiamco
User offline. Last seen 13 years 38 weeks ago. Offline
Use the RA facility to export/import, modify, add datas in activity codes dictionary. You can find this in P3 CD.
