Who is the Owner of Cost Account Codes?
8 replies [Last post]
User offline. Last seen 17 weeks 6 days ago. Offline
Hi to All,
Which department in the company shall be responsible to prepare the Company's Standard Cost Account Codes?
And If in case a new items are introduced, in which these items are not included in the existing Company's Cost Account Codes, which department have the responsibility to add the new Cost Account Code for these new items?
My opinion to this is... The Cost Control DEpartment is the Owner of Cost Account Codes and shall be responsible to add new Cost Account Codes as necessitates.
Comments from the experts please......
Thank you so much guys and I appreciate so much all the valuable comments.
Regards to all,
Raymund
User offline. Last seen 5 weeks 5 days ago. Offline
I agree with Raymund.
General Ledger accounts are designed and used for the accounting needs while Job Cost accounts are optional accounts used for management. They are used for very different purposes.
General ledger accounts must follow the rules of accounting while job costing account can be anything from none to a very detailed breakdown. Some JC systems even distribute labor burden using some average % to the job costing labor distributions, other use a single account or simply do not track them. As you can see Job costing is not limited by the needs of the General Accounting rules.
It just happens that by combining the recollection of data by using the accounting department resources you avoid duplicating the effort and associated cost.
Usually the accounting department post the general ledger accounts while other departments provide the information about the job costing accounts.
The accounting department provides the service but do not manage the operations, the accounting department prepares the payroll but do not tell people what to do and where, the accounting department does not prepare the estimates for bidding your jobs. Usually they do not understand the technical issues that are related to estimating your jobs. It would be a huge mistake to place the responsibility of job costing on a department that do not understand how to get the numbers not to mention how to use them.
The design of the Job Costing shall be on the Operations Manager and he shall consult other managers as well as the estimating department on the required breakdown that meet the needs for managerial functions in the same way he does not tells accounting what shall be the breakdown for the General Ledger accounts.
Of course, some interaction shall be between accounting and operations regarding the design of the job costing system as the recollection and entering of job costing data will be through the accounting modules such as Payroll, Purchase Orders, and other modules or subsidiary ledgers. No way you can leave out accounting from the discussion, but this does not means that its role will be the governing role with regard to Job Costing.
I have seen some articles defining Job Costing as a subsidiary ledger, but in the Construction Industry it is kind of a subsidiary ledger created from many other subsidiary ledgers. So which one is subsidiary to which? It is a parallel system that is key to management of operations but not key to the accounting functions.
It is not uncommon for some contractors to have no job costing system at all but they all must have some form of accounting. A painting contractor that 98% of its activities are painting needs not to have job costing accounts other perhaps than a single account per job, the need is defined by operational needs.
With regard to Job Costing do not underestimate the value of the Accounting department, it is not limited to providing the service but will use it for control purposes, can help to prevent theft unless theft comes from within the accounting department.
Johannes Vandenberg
User offline. Last seen 1 year 5 weeks ago. Offline
Hi Raymund
I have studied the answers on you post till now and i agree with Alan Chadwick. The Finance & accountancy group are responsible for the creation of suitable accountancy system. Your CFO (Chief Financial Officer) in general shall be responsible. The cost control persons are usually responsible for following the guidelines as set-out. The systems should be so designed  that  the cost controller can make sufficient WBS items  or other cost codes to suit the control of the projects.
Johannes
Sankar Vijayan
User offline. Last seen 4 years 25 weeks ago. Offline
Hi Raymund,
Cost Accountant/Cost Engineer/Procurement Engineer  should combined decide this.Cost Engineer Can decide to which code to allocate in ERP ,Accoutant can monitor it, Procurement/store can purshase & issue  it
Thansk & Regards
Sankar Viijayan
Alan,
Thanks for your comment.
In a Construction Company, Technically/Engineering minded personnel should handle the Cost Account Codes as they are familiar with the terms of construction items, in which these personnel belong in the Cost Control Section under the umbrella of Planning, Scheduling and Cost Control Department.
Please correct me if I'm wrong.
Alan Chadwick
User offline. Last seen 11 years 6 weeks ago. Offline
Finance & Accountancy, they should initially be set up in whichever system a companies uses to manage budgets and capture costs i.e. SAP FI/CO  etc.
Planning software is not suitable for controling accounts.
Daniel,
Thanks for your comment..
Daniel Limson
User offline. Last seen 5 years 36 weeks ago. Offline
Hi Raymund,
I agree with your opinion and there should be only one keeper to avoid any misunderstanding. Based on experience, Project Controls normally is the owner and keeper of the Cost Code of Accounts.
Daniel
