Discrepancy on % completed & Total Float
Thomas Ong
User offline. Last seen 20 years 17 weeks ago. Offline
Groups: GPC Malaysia
Planners,
The Percentage complete & total float column on the summary band always change especialy when I sumarise all the activities to its required band. Even I press "schedule", the percentage complete become correct, but sometime I print the report out, the % completed & total float show different.
Anybody can solve this problem?
Vincent Tham
User offline. Last seen 18 years 43 weeks ago. Offline
By solved this problems, i recommended you to execute "re-organize now" command 2 times before every time when you want to explain. sure it will solve your problems.
Sure you have any prolems,you can direct contact me. 012-2867713.
MK TSE
User offline. Last seen 5 years 5 weeks ago. Offline
Both PCT and TF of summary bar are determined by various factors which can be control in Option - summarization.
However, settings may be overrided by parameter in each report template. Please check.
Further, to reduce the changing of these 2 value on screen during editing, stop the auto-scheduling function, hope help.
