s-curve
IDONGESIT ARCHIBONG
User offline. Last seen 14 years 36 weeks ago. Offline
Hello friends. I have been reading the various threads about S curve and its usage.
Pls can soemone kindly give me a step-by-step procedure to plat the s-curve using MS sproject?
I will so much appreciate pls
idong
User offline. Last seen 11 weeks 1 day ago. Offline
Indongesit,
Follow the sample below to access on Analyze Timescaled in Excel, then click and follow the wizard.
MSP Timescale
IDONGESIT ARCHIBONG
Thanks,Rodel. On the Timescled, i see only word and Power point options. Also i dont have Primavera. Pls can you help me get one, so maybe i export and plot there?
Mervilyne Pangan...
User offline. Last seen 17 weeks 4 days ago. Offline
Look for Analyze Timescaled Data in Excel, Choose Entire Project, Select required data and it will automatically show graph you add.
You can customize it on Excel depending on the format you prefer.
otherwise, you export your MICROSOFT PROJECT "Project" to Primavera and Primavera will generate S-Curve.
Idongesit,
You can use the earned value data exported to Excel using the Analyze Timescaled Data in Excel button on the Analysis toolbar.
Display the Task Usage view and show the Analysis toolbar. Click the Analyze Timescaled Data in Excel... button. When the wizard runs, select the earned value information (ACWP, BCWP, BCWS, CPI, SPI etc…) that you wish to export. The wizard will ask if you wish to graph the data as well.
Note: You MSP should be resource and cost loaded.
IDONGESIT ARCHIBONG
Hello friends, Pls i am still expecting aresponse to the steps to ploat the s curve.
many thanks
