Piping activities
6 replies [Last post]
George Bolton
User offline. Last seen 18 years 34 weeks ago. Offline
I am very interested in learning the logic sequence of piping activities for the construction of oil and gas, from the beginning to the end, and its relationship with structural erection and equipments set-up.
Thank you in advance.
Jithin Kambhikanam
Hi George,
You already have the answer. But let me add mine
Pipe Delivery - Shop Fabrication - Pipe Fabrication - Pipe Welding - Blasting - Painting - Pipe field Installation Above Ground - Pipelaying on the support - Welding - Hydrotest - For the whole piping at a time-  Leak Test/Nitrogen Flushing
Dilip Konar
User offline. Last seen 6 years 40 weeks ago. Offline
Dear Sir,
i want rate analysis format of pipe manufacturing process.
like how much manpower, machineries, material required and cosumed enery etc...and testing expenses.
User offline. Last seen 22 weeks 6 days ago. Offline
Hi Dilip
Excavaate > Bedding > String Out > Weld > Test > Cover Joint > Side Lay in Trencg > Backfill 1 > Warning tape > Backfill 2 > FOC > Backfill 3 > Fence / Markers.
Dilip Konar
Dear Sir,
 i want total process analysis  like pipe ( 2500mm innner dia) manufacturing with 20mm thickness plate including sand blasting and black painting outer surface.
Izam Zakaria
User offline. Last seen 7 years 37 weeks ago. Offline
just roughly explaination....
str
prefab that’s mean mark cut act. for stiff,plateand etc
pip
we’ve
mark,cut,install,fit,field weld,soft weld,ndt,hydrotest,re-instate and etc..........
if u want the details act... plaese directly email to me
aizamcapri@gmail.com or maz.aizam@simedarby.com
actually i’m very happy with oil and gas industries...
if compare to design and maintenance side.....
but is better if u can involve with oil and gas...
Charleston-Joseph...
User offline. Last seen 3 years 4 weeks ago. Offline
Hello George,
I know this does answer your question.
How come your in th IT then you find interest in Piping activities.
I’m just curious.
Charlie
