Creating Target plan
Forum Guest
User offline. Last seen 30 weeks 1 day ago. Offline
I want to make a target plan. What shall I do?
Bernard Ertl
User offline. Last seen 10 years 10 weeks ago. Offline
Yes, it appears to be a duplicate thread. I’m locking this one then. We do not need two threads for one subject.
Bernard Ertl
InterPlan Systems Inc. - Project Management Software, Project Planning Software
MK TSE
User offline. Last seen 4 years 37 weeks ago. Offline
Hope they are related.
http://www.planningplanet.com/forum/forum_post.asp?fid=1&Cat=1&Top=3875
According to what pasted, I assume the software is P3.
Bernard Ertl
Folks, the original question did not specify what software was being used. This forum is for general discussions and assumptions should be checked carefully.
Perhaps the original question was answered already?
http://www.planningplanet.com/forum/forum_post.asp?Cat=1&Top=2936
Bernard Ertl
Luca Basile
User offline. Last seen 10 years 2 weeks ago. Offline
Groups: TILOS
As suggested before, copy the schedule.
Open the schedule you updtae. In the load form, go on "Overview", select the Target, and then You can put multiple target.
Let say first the baseline, then last update period.
When You open the program, in the bars management, must add the target bars (target 1 early start and finish) and in a different level(POS), fo example level 2.
The same for how amny target You added or You want to show.
Of course You can compare late dates on so on.
Zq qz
User offline. Last seen 13 years 5 weeks ago. Offline
1st Method. >>> Go to TOOLS >> PROJECT UTILITIES >>> TARGET >> CREATE BY TYPING NAME OF PROJECT YOU WANT ....
2ND mETHOD : COPY YOUR ORIG PROJECT. THEN USE THIS AS TARGET.
You can also go to help for more info........
