Creating Target plan
Pelita De Ramos
User offline. Last seen 20 years 4 weeks ago. Offline
Based from what I’ve red in creating target plan (from P3 manuals). Pls. check the ff procedures if I’m wrong.
1. Prepare schedule with resources.
2. Open tools menu -> project utilities -> target
3. Enter 4 chars. name.
4. Click OK.
But nothing happens, any suggestions will be highly appreciated. thanks. :)
wilfred datinguinoo
User offline. Last seen 18 years 28 weeks ago. Offline
I’ved run a check now on the Project Overview and its ok
and i check also format bar/modify then i didn’t noticed
that my start point is not in Target early start.
Thanks for your help.
wilfred
MK TSE
User offline. Last seen 4 years 24 weeks ago. Offline
I can’t get it. Target bar always parallel to the currect bar except they are placed in same position. Please check the following: -
- Have target been assigned in Project overview
- What option been selected in bar format
wilfred datinguinoo
Hi Guys,
In relation to Pelita’s question, I’ved done copying the project and make it as a target. But when i tried to show the target bar it appears to be not parallel with the current and it shows a long bar. Let say the project starts Jan 2004 and my activity starts May 2004 and end june the target bar shows Jan - June.
Need Help
wilfred
MK TSE
Pelita,
Your method is to assign an Existing project as tartget and/or update the assigned target project by current open project. It is not for creating a project for target from current.
Use Moises’s method, you now have a copy. Then you part is the OK for assign. Or by File - Open - select the current project - click Overview button at bottom left, goto to page Targets, select a project for target assignment.
Zq qz
User offline. Last seen 12 years 45 weeks ago. Offline
Hello Kabayan,
You can also this procedure. Go to the ff Menu
TOOLS>>>>PROJECT UTILITIES >>> COPY ( read in the manual how to copy ...)be sure that copy file and orig file on same folder, then you can use this as your Target.
