Copy Protect on Power Point Files
9 replies [Last post]
User offline. Last seen 22 hours 27 min ago. Offline
Hi All
This is not a planning matter but I would like to be able to stop a power Point file being copied by others.
User offline. Last seen 2 weeks 2 days ago. Offline
Mike,
I think that what Alexandre suggests should work. Make sure you cannot edit the watermark; maybe you can save the slides as picture files and then into pdf or back into Power Point.
PDF files not from a scan can be edited to some extent with Adobe Acrobat Pro.
Always keep editable files and their backups.
Keep open the option for very long and difficult to crack passwords. Microsoft site have some suggestions. These passwords can only be cracked by “Brute Force” methods and will take so long will deter almost anyone.
A combination af all tricks plus a long password will drive crazy any hacker.
Hi All
Thank you all for your valued input - you have confirmed what I thought - it can’t be done.
So I will fall back on printing and binding and distributing hard copies - if anyone wants to scan pages and convert to powerpoint then let them.
Mike,
A few months ago an owner sent us an MS Excel spreadsheet password protected; I unlocked it using Elcomsoft MSO Password Recovery and recovered the hidden password. This was the spreadsheet where we were to submit our bids.
Even MS Windows have been hacked, but general use software seems to be easier to unlock.
http://www.elcomsoft.com/
For PDF files I still prefer PDF Password remover.
Scarllet Pimpernel
User offline. Last seen 13 years 21 weeks ago. Offline
I would suggest
Make a hard copy.
Then delete the file, throw in the re-cycle bin. In this way nobody can copy the power point file.
Simple
Thank you,
Scarlett
Rubas M. Kutty
User offline. Last seen 10 years 32 weeks ago. Offline
Mike
If your intention is to have unique users or if you wish to protect users from making changes, the best way might be to set a password for the PPT file. In any other case, if the powerpoint is opened, the content could be copied.
For setting up the password: Tools>Options>Security>Password to Open/Modify
Kind regards
Rubas
Very PDF Password remover can remove the protection at the click of the mouse, very fast no need of "brute force".
100% success up to date. You can e-mail me your PDF I will return it unlocked.
