Why does my budgeted cost change every time I recalculate the schedule
T
Tom Tom 👤 Member for 11 years 10 months
I just created a cost loaded schedule and everything look fine. The problem is that everytime and re-run the schedule the budgeted cost changes on me and it driving me crazy. This only happen on a particular resource. P6 always always add or subtract some decimal points to whatever I input.  For example, $350,000 would change to $349,999.78. What is going on?
T
Thank you. I talked to oracle about it. The problem was that P6 can only handle up to 6 decimal points. Anything after that will be truncated when you close the schedule.
Z
ok look at that one particualr resource and see how it is different from the others. You can aldo go to the activity directory and click on the resource tab at the botom and then right click in that lower window and add a column for calculate cost from units.
T
Tomasz Szłapa 👤 Member for 10 years 5 months
Hey Tom!
Check out Reources if the Calculate cost from units is unchecked.
Best compare these two different resource according to this option.
Johannes Vandenberg
Soheil Barekat
Peter Holroyd
Neil Atkinson
Trian Asmoro
Erkan Polater
Luis Jr Ngade
Ben Welsher
Rohan Dashputre
