P6 Beginner Question - Can you delete same predecessor from multiple activities
sam dsoza
User offline. Last seen 6 years 25 weeks ago. Offline
Hello All,
So I am not new to P6 but have forgotten most of the skils for not having to use it.
My question as the subject line mentinos is if you could delete predecessor form multiple activities. Please advice.
SD
Ronald Weaver
User offline. Last seen 3 years 43 weeks ago. Offline
Yes you can!
select one of the activities with the offending predecessors
in the "activity detail" window, select "Predecessors" tab
highlight the offending predecessor or predecessors (yes you can delete multiple predecessors)
Click the "Assign" button on the bottom
once the "Assign Predecessors" widow opens go back to your schedule layout and "Ctrl" select all of the activates with the offending predecessor
Go back to "Assign Predecessors" window, click the red "X" button.
User offline. Last seen 21 weeks 3 days ago. Offline
I suggest to select all activities with the same predecessor then from the predecessor window select the predecessor activty then unlink by clicking the red button x.
User offline. Last seen 25 weeks 5 hours ago. Offline
within P6 you can only delete multiple predecessors from and activity but you can not delete the same predecessors from multiple activities.
You can do this with sdk and the associated spreadsheet.
EVERYTHING is based on the activity id not the predecessor id
