Facing problems with comparing between baseline and Updated one
6 replies [Last post]
Hossam Eweda
User offline. Last seen 10 years 40 weeks ago. Offline
Dear All,
I need your help
Why
1> when i assigned baseline with the updated Sch. i found the percent on (performance % complete) column changed
from 41.06 % to 40.92
2> How i could compare between base line and the updated
when i showed (planned value, actual value, remainig value, budget value) not right values like example
remaning value + actual value        Not equal     Budget total cost
and planned or Scheduled vlue -  Actual value       Not equal   variance value
3> and why actual cost column give me value equal zero although    performance % complete equal 41.06%
thank you for help
Hossam Eweda
Dear All
I found the respone
You need to use (Apply actual ) from tools after every update to calculate the actual cost from your updated percents
but notice that step no undo for it you cant come back with data date, for that you need to make export first for your project.
Hossam Eweda
Dear i am realy grateful for your interest
 i am already checked that box for item i know it has a problem for calculating
and i am sure that all items already marked as auto copmute
and i made Recalculate the assignment cost"   from tools
but it still not working
Hossam Eweda
i found PF = .88    not equal (1) i think it ought to be (1)
to give me the right equation
budget - remaning = actual
but when i changed it no new action and no change on the value of remaning still same number
Still the main Problem with me that Actual cost for some items not calculating atuomaticaly.
AB Timo
User offline. Last seen 10 years 8 weeks ago. Offline
Hossam
If you have not checked auto-compute actual box,then cost will not be filled according to % Complete.
you need to enter actual cost in actual cost column or if you want primavera to compute based on % complete then you need to check auto-compute actual then Run "Recalculate the assignment cost"
May be it will solve the problem
Hossam Eweda
Dear AB Timo
Thank you for trying but i tried that it not working
Still Actual cost zero for all items
still remaning plus actual not equal budget
about changing performance % from 41.06 to 40.92 after assiging baseline it solved when i assign baseline just on the project baseline not in primary one
but i still facing the 1st problem
AB Timo
