Calendar is causing budget to change
Cynthia Stiffler
User offline. Last seen 36 weeks 3 days ago. Offline
Hello;
I am starting to add budgeted labor units to my schedule.  The activities have a duration type of "Fixed Duration and Units/Time.
I set up my resource id's and assigned them to the activities.  When I go to add the budgeted labor units of say 100 , the budgetd labor units column says 80.  When I look at the detail I see the electrician has 100 budgeted labor units.
User Preferences are:
Resource Anaysis Tab
Opened Projects Only
Remaining Early dates
Custom Role Limit
Calculations Tab:
Recalcutate the units...
Assignements are both set to ask
Project Settings are: Calculations
Link Budget at completion
Reset Remaining Durations and Units to Original
Subtract Actual from At Completion
Link Actual to date and actual this period units and cost.
I cannot find that this is a setting feature - the resource calander is a standard 5 day workweek - and I have created new calendars.   Is there a setting Im missing?
User offline. Last seen 12 weeks 6 days ago. Offline
this is based on your resource and what you have set for Default Units/Time if it is set to 8/d
then it takes 8*the duration and give the manhours
so fo the duration is 10 days the 8*10= 80 manhours or units
you can change them manually or do them all at once then export to excel change the manhours save it then import back into P6
david kelly
User offline. Last seen 5 weeks 4 days ago. Offline
A bit more detailed explanation please, Cynthia.
You add an actvity with what duration on what calendar
Then you add a resouirce assignmnet record, with a resource on what calendar
you add 100mhr into whiich field
Which budegeted labour units field (resource or activity) then says 80, or is it both
