how can i do this
David Smith
Peter Holroyd
fridau
Rahmat Hidayat
pinoyplanner
Saqib Ullah
Luyanda Ndlumbini
Jeff Waldrop
Robert Roy
you can use start or finish varience columns to show this or if you are using 2003 or later there is a wizard to compare 2 project files and listt all the changes between them
hope that helps
Dave
Hi Ahmed,
There must be a column of DURATION VARIANCE. Double Click on the column head and add this column in the field name.
This shud solve ur problem
yes i did but i want an empty cell telling me that this activity is delayed by 20 days or 10 and so on for each activity can i add an empty column and make formula to substract the start date of every activity and the status date???
