Table Definition User Fields
d asd 👤 Member for 18 years 3 months
Hi Hopefully someone will be able to help.
I wish to have multiple "text only" fields in the columns. Asta bydefinition has 5 user text fields.  I need 4 or 5 more.
I have followed the asta help tool and done the following
 1 entered the user field manager in the project tab
2  select "USER"  from the "object type" dop down.
3 Added new fields as STRING type with new names.
4 applied the setting and sved.
When i then go to the Column type as it suggests in the table nothing shows up to select.  What am I doing wrong.
Thankyou in advance
Sam
Thanks Mike
I knew there was a way.  There usually is in Asta. Cant be said of some other software...
Sam
M
Hi D
Welcome to Planning Planet
Step 2 - Select BAR from the "Object Type" drop down - not USER.
You can have any number of user fields in the system - just select the ones you want to display.
Ola Gbotoso
Jaturapit Multongka
Haque Nawaz
EViLL1
Dimitrios Theocharidis
MichaelFuelsC
anwar zeb
olva seselima
Muhammd Muneer
