Task Formula for Bar
Chris Lothian
User offline. Last seen 1 year 50 weeks ago. Offline
Hi All,
Does anyone know how to get a formula that displays information about a task for the bar (whole line)?
e.g.
I have mutliple tasks per line, and 1 task on the line has a start constraint flag on it. I want the formula to flag up if the task isn't starting on the day of the constriant.
The formula i have so far is below, but i can only get it to work when I display task per line;
IF((Type="Task" OR Type="Expanded Task") AND (Task.CodeLibrary(35,0,na)="ABC"),IF( StartConstraintDate=Start,Bar.NONE,Bar.HIGH),Bar.NONE)
 The result is a RAG, but as i stated above, it only displays properly when I display task per line, when the bar is on 1 line the RAG displays Grey (NONE). Thanks, Chris.
Craig Adams
User offline. Last seen 3 years 28 weeks ago. Offline
Hi Chris,
Create a code for your key deliverable and apply it to the task with the constraint flag on it then insert a column that sources/filters for that code to display the RAG column.
Kind regards,
Craig
User offline. Last seen 31 weeks 2 days ago. Offline
Hi Chris
Asta do not make it easy to apply formulas to the spreadsheet.
They should at least have a library of common formulae.
Perhaps this will come up in version 13.
