Using Formula answer in another Formula
Chris Lothian
User offline. Last seen 1 year 42 weeks ago. Offline
Hi all,
Does anyone know how to / if you can refer to an answer of a formula in part of another formula?
If you can, could you please explain how?
Kind Regards,
Chris
Chris Lothian
Thanks Chris.
Keeping them simple, and a lot of trial and error is the only way i can get a formula to work, so was hoping to avoid creating complex Formulae. If you're able to help, i've posted again with the details of the specific formula:
http://www.planningplanet.com/forums/asta-powerproject/537833/formula-duration-between-tasks-based-code-library-allocation
Chris
Chris Ray
User offline. Last seen 10 years 17 weeks ago. Offline
Hi Chris,
if your not able to refer to other formulas, you will need to add the existing formula into the new formula e.g
formula 1 - display long for all task over 10 days and short for less than 10 days
if(duration > '10d', "Long","Short")
formula 2 - depending on the result of Long or Short display different messages
if(if(duration > '10d', "Long","Short")="Long","Task over 10 days","Task less than 10 days")
I would always recommend that when building a new formula, build it in small sections so you know that each part works.
