how to add more items in code libraries
HI,
I'm using Asta easyplan. I'm creating a tender programme. I'm trying to put all of the different stages into different colours so I used the code libraries option and dragged the headings to the tasks and then renamed the headings.. I assumed I could just add more items into the code library by right clicking however I can't see how to add more so I'm stuck with the 6no in designers that I started with.
Can anyone tell me how to group my tender programme in colours effectively without running out.
M
Hi Duncan
It may be that easyplan has a limited number of codes that can be created.
In PowerProject I just left click under the last code and type in the new code in the box.
Like Robert I have a standard set of codes but for live projects I use only 4 - 1 for each level of programme detail.
duncan burns 👤 Member for 16 years 10 months
Yes Robert it worked perfectly.. THank you so much (I might get out of here by 5 now!!)
Robert Hughes 👤 Member for 19 years 9 months
Duncan,
I have never used easy plan, however in Power Project you would need to:
 - Open the library explorer (View->View->Library Explorer)
 - In the pane on the left hand side select Code Library
 - Work through the folders in the pane on the right hand side until you arrive at your list of codes
 - Right-click and select new code library entry, enter the name and format the colours and pattern as required.
(I have a standard set of codes in my Asta template and then a list of codes which are just titled 'a' this way they appear in the project view and can be amended there and applied to bars without having to go through the library)
Hopefully this will be of some help to you.
Featured Partner
Hamzah Ahmed
Quinton van Eeden
Sunchana Johnston
Akram Hammam Mohamed
Sagar Raut
Patricio_aoa
Philip Assou-Dodji
jeoffrey reyes
markg
