XER WBS import errors
Andrew Watts
User offline. Last seen 9 years 22 weeks ago. Offline
Has anyone encountered errors when importing a WBS IDs into Primaverea Risk Analysis (PRA). What should read
C512-R45/P2.0.010-001.2 (P6)
is reading
C512-R45/P2.0.010-001.0280 (PRA)
It is as if PRA is ignoring the data in the XER file and just auto-incrementing the last 4 numbers as "0280" does not exist in the XER file - I have checked in Notepad.  The correct data is also available in the XER it is just that PRA is not using it.
Levels 1 and 2 import correctly - it is 3 onwards that it just whimsically assigns WBS IDs to. Any ideas?
I have tried getting the planner to export v6 and v7 XERs. There are no user fields with the correct ID in either.
All the task IDs import correctly.
Dennis Hanks
User offline. Last seen 8 years 32 weeks ago. Offline
Andrew; Yes. I create a UDF called, appropriately enough, PRA_WBS and sort on that. There may be better ways, but that's what I use. Good luck. I use it, even when I use direct import/link. PRA does not look at WBS coding the way I do. Not sure we have the same situation, but a UDF may solve your problem.
