Progress and S-Curve for Engineering, Procurement and Construction projects
Raul Santos
User offline. Last seen 6 years 25 weeks ago. Offline
I would like to ask the experienced guys in EPC companies or projects (EPC = Engineering, Procurement, Construction):
- What approach do you follow to track progress and develop S-Curves for EPC projects?
- How do you do this for each of the phases? (for Engineering, Procurement, Construction)
- How do you combine all the phases into a single one to obtain the Overall Progress for the project?
sunil k
User offline. Last seen 11 years 48 weeks ago. Offline
Sir,
Please send me the copy at sunilkmrpl@rediffmail.com
Sunil.k
RAO RAO
User offline. Last seen 13 years 37 weeks ago. Offline
Hi pieter please send me a copy please at veta_13@yahoo.com
Pieter Bezuidenhout
User offline. Last seen 13 years 36 weeks ago. Offline
Hope my example help you to give you an idea.
Jose Frade
User offline. Last seen 4 years 5 weeks ago. Offline
Bom dia Raul,
I would make a diferrence regarding relative weight between the phases and how to track physical progress (It would also help to know what kind of project you have on hands).
Normally in a project you sold to your client the project divided in diferent chapters :
1 - Engineering (and price) - normaly client also knows the global price
2 - Procurement (and price)
3 - Construction (and price)
So in order not to disturb this relations the overall % progress would be calculated having in consideration the relative weights of the budget sold to client (this method avoids  a lot of questions in the future)
Now the phisical progress and relative weight of individual activities
 - Engineering
If a detaield documetn list to be produced exists, then use it and atribute a relative weight to each doc (in MH and according your own budget - meaning total 100% of engineering would sum up the total MH you have to spend in engineering).
- Procurement
In the type of projects I am involved normaly I give a relative weight to each activity based on my budget value (not MH) for that particular item (total procuremtn phase shall sum my total value budget for the procurement)
Physical progress can be taken from progress reports of manufacturers, expediting teams, etc for each item.
Construction
Here it would be good to use again MH. You have to calculate (or distribute your MH budget) the required MH for each activity.
Phisycal progress has to be calculated according each discipline (excavation in M3, piping in tones, electrical cables in Klms, etc, etc)
Progress curves
Can be drawn directly from above explained methods
Hope it contributes to solve part (rsrsrsr) of your questions.
BR
JMFrade
Pieter Bezuidenhout
Well we simply used Excel to form 3 S-curves 1 for Fabrication 1 for Construction and then we created 1 using both Fabrication and Construction to form a overall.
You will first need to create a planned sheet for each like dates with percentages planned and actual so you got a bar.
Example
 12/10/201019/10/201026/10/201002/11/201009/11/2010
Planned % 3.4%6.9%10.3%13.8%
Actual %  1.0%2.0%
3.0%
then from this you should be able to perform a s-curve if you need a softcopy drp me a mail and i will send you mine for an example.
