Copying project in P6, filters turn up empty
Håkon Haukebøe
User offline. Last seen 5 years 39 weeks ago. Offline
Hi all.
When i copy a project within the same EPS in P6, the new project turns up with all filters empty (they are there with the filter names, but conditions are empty). All filters I use are under the "user defined" tab.
Is this fixable?
Haakon
User offline. Last seen 12 weeks 6 days ago. Offline
You are using a filter criteria that is just applicable to the source project such as activitiy codes under project, etc...
Håkon Haukebøe
All filters are there with the same name. They are empty, wich means the dont filter anything.
John Sims
User offline. Last seen 11 years 20 weeks ago. Offline
so all the filters that you have made in your user field are gone? is the same layout applied? if not make sure you have the same layout applied otherwise the filters will be different.
Håkon Haukebøe
When i open the new project, all filters are empty. That means I must re-define every parameter in them to make them work.
John Sims
why not just apply the filters again?
