Copying Layout with Filter
Vijay N.K.
User offline. Last seen 13 years 11 weeks ago. Offline
Hai, can any one help me.
How can we copy a project along layout with filter.
In my program, I had saved layout with filter, but after copy, paste and make updation and opening it, in that saved layout have no filter. Can you help me.
Vijay
Vijay N.K.
Thanks Mr. Rodel,
You are right, I used project activity code and I will change to global and will try. Thank you
Vijay
User offline. Last seen 4 days 21 hours ago. Offline
Vijay,
What type of filter did you save on your layout? Is your filter using a global activity code or Project activity code? If the filter used is specific to Project and not global the filter will not work on the other project.
Ex: If filter by Project specific Activity code then that activity code will not work on other Project even it has the same name unless activity code is define as global.
