Is there a way to copy&paste activities between 2 opened projects in P6?
Ayman Eleish
User offline. Last seen 13 years 7 weeks ago. Offline
Dear All,
Is there a way to copy&paste activities between 2 opened projects in P6?without using WBS.
Sethupathy Subram...
User offline. Last seen 3 years 33 weeks ago. Offline
Greetings,
Make sure of the following while copying and pasting activities between two open projects in P6
1. the calendar assigned for the activities
2. activity codes assigned (if any)
recently i  faced these problem after copying when i checked the above things i found that the calendar for activities it took a global default calendar and activity codes were never really copied. Resource assignments were proper.
Sethupathy
Ayman Eleish
Adrian,
You are completely right but that can not be done unless you organize the layout by WBS.
Is there other method to do the same without organizing with WBS.
Adrian Nicholas
User offline. Last seen 8 years 9 weeks ago. Offline
Ayman,
Just Open both Projects together and copy the activities you want and paste them on to the destination project that  you want it to go to.
Adrian N
Adrian Nicholas
Ayman,
Adrian N
