How to Keep Resource Usage Profile Time Period Filter After Clicking on Activity Details
Christian Glorieux
User offline. Last seen 13 years 22 weeks ago. Offline
Hi All,
I have leveled my resources however they remain over allocated in some instances.  That said, I would like to know if it is possible to view the "resource usage profile", select a "time period" to display the respective activities for that resource(s), then go into the "activity details" to adjust allocated resources if applicable; however when I do this, the "activity filter" for the "time period" from the "reource usage profile" is lost when I click the "activity details" tab.  I was therefore looking for a way to keep that "time period" filter from the "resource usage profile" while I am in the "activity details" tab.  Any help on this would be much appreciated.  Thank you for your time and have a good day.
Christian
Christian Glorieux
Hi Mohammad,
Thank you for your help.  I have used your concept in principal by creating an activity code and filtering it out and it works however I would be interested in understanding your method detailed above.  Currently I have resource ID's allocated to each resource assigned however what does the Value "TL" mean?  I tried to create a filter as you mentioned above however no results were derived when I applied it.  Please let me know your thoughts when you get a chance.  Thank you for your time and have a good day.
Christian
Mohammad Mojahid ...
User offline. Last seen 10 years 37 weeks ago. Offline
Dear
if you want to see the activity
Click Project then activity
go to column and create Resource IDs column
then go filter
Display all rows Parameter Is Value High Value
                      Parameter                      is                          value
  Where          Resource IDs                   contains                TL
you will get what you want.
