Resource Assignment using Export/Import
Ariel Malibiran
User offline. Last seen 6 years 21 weeks ago. Offline
Hi everyone!
Need some help pls..I have loaded my resources (Labor and NonLabor) in the schedule using the export/import functions. The odd is after the importing of resources, the Resource Type for all the NonLabor resources I have imported were changed to Labor although it were NonLabor in the spreadsheet I have used during the import.
Ariel
PINAN T.
User offline. Last seen 7 years 4 weeks ago. Offline
In the menu, select Help then click about primavera
you will see the release version
or from your exported xer you can open it in notepad then you can check it if 6.0.0.0 means p6 version 6
Ariel Malibiran
Mr. Pinan T.
I think im using P6.0. Not so sure, coz I just got it from my friend. You're right, exporting and importing the schedule in XER solved the inconsistencies. By the way, how can I know exactly the version of P6 I am using? Can't find it the properties of P6.
Thanks again,
Ariel
PINAN T.
hi ariel
which p6 version did you use?
6.0 or 6.1 bug i think
export the project to xer then import as new project will solve it in 6.1
6.2 and later version solved this problem
