Export Resource/Cost Assignment to Excel format.
8 replies [Last post]
tandyo winarno
User offline. Last seen 13 years 51 weeks ago. Offline
Dear All,
Would you please advise me how to export Resource/Cost Assignment shown from Assignment menu on the Directory Bar?
Tandyo
tandyo winarno
Thanks a lot Arend.
I follow your guidance and it works.
Tandyo
Arend Kok
User offline. Last seen 11 years 8 weeks ago. Offline
Tandyo,
You can also use the report wizzard to set up the fields over the time distribution you need and then output the report to a csv file.
Arend.
tandyo winarno
Thanks All,
You are right. It works.
I tried on other machine (local database) and it works.
I work in the server database and can not work for such function.
Tandyo W.
Amit Parmar (PMP)
User offline. Last seen 12 years 23 weeks ago. Offline
You can try exporting data to an excel sheet, using the export function. You can design the template and set the data you want to export based on filters and columns
Amit Parmar
check out my blog on Primavera at http://www.primaverablog.in
Amit Parmar (PMP)
What all data do you want to export from Primavera?
Amit Parmar
Check out my blog on Primavera at http://www.primaverablog.in
User offline. Last seen 13 weeks 4 days ago. Offline
Hi Tandyo,
I am using P6 and it works well by selecting, copy and paste. In the excel, I can see the loads in time intervals.
272
tandyo winarno
Thanks Raymund,
I already did, however it works only for resource description shown in the screen shot at upper left while it doesn't work for the resource assignment shown in upper right (resource assignment for every month/day)
Tandyo
Select Resources>>> Copy >>> Paste in excel.
Hope this will help.
Raymund
