Updating With Resource-Costs for Corps
Emily Grover
User offline. Last seen 13 years 23 weeks ago. Offline
I have a P6v7 schedule created with the cost for each activity as a resource (rather than Expense, so that it can be used to create an SDEF for QCS input). The 'calculate costs' and 'auto compute' ticky-boxes are ticked. When I update the activity percentage (physical), both simply in-progress or complete, it clears the dollars out of the budgeted cost in the resource (setting it to $0).
I understand that P6 is unequated (dollars and durations will not run off the same entered percentage) so I already know I'll need to enter each update twice. But I'd really like to have the budgeted total stick around so I know how much it is without flipping back and forth to a previous schedule. How do I keep the resource-loaded budget from clearing when I update?
- ES
User offline. Last seen 8 weeks 2 days ago. Offline
Emily,
I'm sorry was not able to get a solution for the prob. It's rare.
I doubt there might be mistakes while assigning the resources. Try removing the resource and reload, recalculate.
Or maybe try having a new sample project and do the exercise.
Emily Grover
Raymund:
Here it is before:
305
After I mark the activity 'completed' in the drop-down box for Activity Status, the following is the result. No other changes were made to the activity. Note the 'Budgeted Nonlabor Cost'.
306
Hopefully that helps clear it up!
- EG
Hi Emily,
I can't figure out what exactly the problem happens with your Project.
APMU Budgeted Cost shall be intact even the project is updated.
Can you share a screen shot of your project?
Emily Grover
Raymund, thanks for the suggestion!
I've looked through those options and I'm not seeing what ought to be different. Just in case, I tried all three options down in the bottom-most area and the budgets continued to clear. Is there somewhere else I should be looking / changing?
Thanks again!
- EG
Please check the settings of your Earned Value Calculation on the Admin Preferences.
Hope this will help.
