Same value of Budget Labor Units and Custom Defined Field using global change in P6
6 replies [Last post]
Num Lock
User offline. Last seen 12 years 18 weeks ago. Offline
Dear All,
Hi, I already have values in my custom defined field "WF". I cannot use global change so my Budget Labor Units will be equal to the values in my custom defined field "WF". Any work around?
Thank you.
Num
Num Lock
Hi, anyone has solution for this one? Thanks.
Num Lock
Num Lock
Hi, I simply use 2 global change:
1. Global change 1 (Activities):
user_number6 = _sc wf
2. Global change 2 (Activity Resource Assignment):
Budgeted labor units = user_number6
Num Lock
Hi I already changed the security profiles but still it doesn't work.
Amit Parmar (PMP)
User offline. Last seen 12 years 42 weeks ago. Offline
Can you please tell me what formula are you using while using global change.
Amit Parmar
Check out my blog on PrimaveraBlog at http://www.primaverablog.in
User offline. Last seen 32 weeks 3 days ago. Offline
Hi Num Lock,
Please check your Security Profile assigned to you if you are not a superuser. You might not allowed to edit part or whole of the project data.
Hope this will help.
Raymund
