Change activity project codes assignments from a User Defined Field using Global Change in Primavera P6
Baz Kawar
User offline. Last seen 2 years 10 weeks ago. Offline
I am having difficulty using Global Change to set to assign to an activity the Activity Project Code value from a User Defined Field Value, it forces me to mannually enter the Activity Project Code value, Why? it should allow me just to simply to make the code value equal the value in the User Defined Field.
User offline. Last seen 27 weeks 6 days ago. Offline
as always the code defenition must be already setup
once this is done importing values from excel is much easier
why dont you export and activity to excel that has the global code and use it as a templete for importing values back into p6 via excel
User offline. Last seen 51 weeks 2 days ago. Offline
Baz, do it via Excel Import - will be much easier to do than manually as you already have the values assigned in th UDF fields.
David Kelly
User offline. Last seen 2 years 41 weeks ago. Offline
Yes, That would be a great idea. I suggested it to Oracle in 2011. Welcome to the club, Baz
