When I make down the original duration , the ressource allocation became overloaded but the unit/TIME didn't change
6 replies [Last post]
walid Lahiani
User offline. Last seen 8 years 39 weeks ago. Offline
Hello ,
Explication :
Imagine we have a Labour who works 8h/day and an excavation task ,
the original duration of the task is 10 days
so ,this laber will work a total of 80h ,
If i change the original duration to 2 days ,normally this laber have to work  40h/day => 5 labers/ day
But in the table we have always 8h/day (unit/time) =>one laber only
Thank you
BONG YAGAHON
User offline. Last seen 1 year 28 weeks ago. Offline
What is meant by  "Explication"    as you telling in first line?
ty.
BONG YAGAHON
ty.
pei tang
User offline. Last seen 12 years 28 weeks ago. Offline
i want to say "fixed duration and units" and "fixed units" should produce the same results.
Amit Parmar (PMP)
Glad to be of help :)
walid Lahiani
Good morning
Thank you for this very interesting table
Amit Parmar (PMP)
Change "Duration Type" to "Fixed Units" in the activity and you would be able to see the changed rate. By default your "Duration Type" would be " Fixed Duration & Units".
Duration Type follows following formula :
  • Remaining Duration = Remaining Units / Remaining Units/Time
  • (Original/Planned) Duration = (Budgeted/Planned) Units / (Budgeted/Planned) Units/Time
hence changing the Duration Type affect the resource and duration calculations in the following ways :
    Duration Type
Change UnitsChange Duration
    Change Units/Time
    Add 1st resource
    Add additional resources
    Fixed Units/Time
DurationUnits
    Duration
    Units
    Duration
    Fixed Duration & Units/Time
Units/TimeUnits
    Units
    Units
    Units
    Fixed Units
DurationUnits/Time
    Duration
    Units
    Duration
Unit s/TimeUnits/Time
    Units
    Units
    Units/Time of each Resource
