Adding Resources using Global change
Haresh Jayanth
User offline. Last seen 6 years 46 weeks ago. Offline
Hi Rodel,
Normally whenever i want to assign resources to set of activities , i export in excel and use fill cell to assign resources to activities.
In P3.1 , we have add option for resource in Global change, wherein we add resources for the selected activities.
In P6.0 am not able to see this option of adding a resource thru global change.....pls help out..
regards,
Haresh Jayanth
Haresh Jayanth
Thanks very much Rodel.
regards,
Haresh Jayanth
User offline. Last seen 22 hours 25 min ago. Offline
Haresh,
You need to change the subject area in order to select resource as per sample below.
GC Resource
Haresh Jayanth
Dear Rodel,
I have done Resource assignment by assign resource icon. But still i am not able to assign resource using Global change for selected activity......
In if criteria , i have given some criteria and in then criteria , i am trying to assign resources for the selected activities...but i am not able to get in the parameter column"Resource assignments" , can u help me out.
regards,
Haresh Jayanth
Haresh,
P6 is the same as P3. You can change the resource assignment using global change:
You have to change the subject area to Activity Resource Assignment and you find resource field once selected.
Note: P3 & P6 will be able to change resource assignment if there is existing resource. If there is no existing resource then you cannot add new resources to activity.
To Add resource to multiple selected activities, highlight all those activities and click assign resource icon on the right of the screen then select the resource you want to assigned and all activities selected will have the resource.
Rodel
