Changing Activity ID inbetween using Global Change
Haresh Jayanth
User offline. Last seen 7 years 8 weeks ago. Offline
Suppose i have around 50 activities with activity ID SUTSGF001,SUTSGF002....and so on.....
I want to change all activities in that WBS to SUTSFF001, SUTSFF002....and so on..i.e to replace "GF" to "FF" in the middle using Global change.......What is condition i have to apply....
User offline. Last seen 13 weeks 6 days ago. Offline
Haresh,
In addition to Pinan response below is another Global Change parameter that you can use.
If
where WBS is under (select the wbs containing activity to change)
Then
Activity ID = SUTSFF & RightString(Activity Id,3)
In this case it will limit only on WBS stated and not all activity with SUTSGF.
PINAN T.
User offline. Last seen 6 years 43 weeks ago. Offline
The simplest is Replace Function (Control R), Find GF and Replace with FF
By Global Change, You can try a simple one
If
Activity Id starts with SUTSGF
Then
Activity Id EQ SUTSFF & rightstring(activity id,3)
