resource reports- hourly distribution
Alaa Al haj 👤 Member for 18 years 8 months
Arnold,
You don’t need to change the duration format, and it will work as long as the resource analysis is in hour.
Alaa,
How many hours per day are they working? Are you using shift/day?
You can organize your resource by WBS level 4 then Resource then Start. Under Start group interval change to day as shown below
Group & Sort
Arnold Puy 👤 Member for 19 years 2 months
Hi Alaa,
Go to Resource Assignment and Group it by Resource ID or Name.
Arnold
thanks arnold
actually here I have 2 problems
1- I want to see all resources fro each unit separately
2- the resource distribution in hour
I will try what you advice and get back to you
Hi Alaa,
Is your Original Duration is in Hour? Otherwise, if not the resource distribution will be in days.
Change the Day into Hour. Go to Edit --> User Preferences --> Time Units Tab, "Units & Durations Format". Similarly, change the Resource Analysis from Day to Hour.
When done, try to adjust the Timescale, Date Interval to "Day/Hour".
Arnold
Abkar Bannayan
christiandt
J Vaartjes
Aidar Kurmantayev
Noe Radovan
GeoVe
Johannes Vandenberg
Soheil Barekat
Peter Holroyd
