Migration of P6 files (from one pc to another pc)
Izam Zakaria
User offline. Last seen 8 years 29 weeks ago. Offline
What the best way to migrate P6 files from one PC to another PC. Currently what I did, I exported the files one by one. Is it we’ve easy way such like copy the P6 folder or something else?
Izam Zakaria
Thx raviraj and tamara...both solution is useful
Tamara Sutton
User offline. Last seen 9 years 33 weeks ago. Offline
Export/Import will work, but I believe export does not export baselines? If that is true, and you use baselines, your best bet would be to backup the entire database using the Oracle or SQL utility.
A D
User offline. Last seen 4 years 33 weeks ago. Offline
I believe, what u r looking for is backup ur database and use it in another computer
Here’s the link for ur answer:
http://primavera.zxlm.cn/kb/prim54984
Abeer Mahmoud
User offline. Last seen 9 years 2 weeks ago. Offline
Hi Izam;
You can open many projects at same time by the following steps:
Projects --> chose required projects to be open by ctrl + left click --> open projects --> file --> export (program takes all open projects under a new project name)
And after that you can import projects as a spread and also at different projects enterprise.
Abeer
