Total Original Duration!
Jonald Calaycay
User offline. Last seen 12 years 29 weeks ago. Offline
Guys,
Greetings! i have imported a project from p3.1 to p6. most of what i imported is ok. my concern is that the total duration is not matching with what i imported. even i set the calender same as p3.1.
regards,
Jonald Calaycay
CAT Group Int’l (UAE)
Arnold Puy
User offline. Last seen 10 years 21 weeks ago. Offline
Hi Jonald,
First of all welcome to Planning Planet.
The Total Original Duration in Summary band calculated based on the "Default" calendar.
In order to change the summary duration you must select the calendar that your current project used. To do that, go to --> Enterprise --> Calendars, select the calendar that your project currently used and mark the check box "Default".
Arnold
Jonald Calaycay
Hi Izam,
The ES are all the same except the Gap is from 425 to 531.
Thank you for the reply.
Jonald
Izam Zakaria
User offline. Last seen 8 years 29 weeks ago. Offline
How gap it is? Did ES equal each other
