Primavera Tip & Trick
Mohd Shahrizan Ab...
User offline. Last seen 14 years 10 weeks ago. Offline
Groups: GPC Malaysia
Tip and trick for Primavera P6.X.
As you can see using Primavera P6 with integrated database system MS SQL SERVER are memory eater even do we are not running the programme. The are several "pre-load" running service or background service on startup Windows. Actual don’t need it, cause when we are having on less 1Gig RAM in ours then the laptop or desktop will starting moving "slowly " especially after we open then close the Programme.
After we close Primavera the best thing to do is to free up our laptop/desktop RAM memory by
1. Click Start The select RUN
2. Type in the box with this command line {net STOP "SQL Server (PRIMAVERA)" } without { }..
it will stop the service and freeup a lot of memory space.
To using back the Primavera Programme just do back the above step but with a command line {net START "SQL Server (PRIMAVERA)" } without { }.. before run Primavera P6.
Another Method is by creating MS-DOS Batch file...
Simply by open notepad programe or type in RUN command line notepad.....
put this below command.....
@echo off
then save as the file at desktop as SQL_STOP.bat
do another file with above method with the following command...
@echo off
then save as the file at desktop as SQL_START.bat
Ezra Nyakundi
User offline. Last seen 7 years 19 weeks ago. Offline
Read of the following solution which has detailed steps on how to solve database Error,
By Ezra Simba
Sabri Ghani
User offline. Last seen 14 years 49 weeks ago. Offline
hi shahrizan,
it’s a good advice.
can i know your experience background? which industry are you working now?
keep in touch....
