Hotkeys/Tips/Tricks in Primavera
6 replies [Last post]
Valentin Sendula
User offline. Last seen 10 years 12 weeks ago. Offline
Maybe anyone who knows tips and tricks to easier input loads of info could post their tricks/tips/hotkeys in this thread.
As a new user I am still discovering new ways of making working in Primavera easier.
I was wondering if anyone knows any hotkeys in Primavera, like you have in MS Office. For instance Ctrl+C = copy, Ctrl+v = paste, Ctrl+X = cut.
Also the other day I discovered that in Assignments you can do a fill down on the Budgeted units. This is easier, cause otherwise you have to change them one by one in resources tab, cause adjusting them in the column BL Project Labor Units is not possible, while under assignments you can change it in the column.
So whatever you experienced guys know and think this might be useful to a newbie, please post it here.
I myself hate the lack of the possibility of hotkeys and macro’s in P3E.
Thanks.
User offline. Last seen 15 weeks 5 days ago. Offline
what you mentioned are standard windows operating based short cut and will work in any windows based program and is not just MS Office based
F9= schedule project
F5= Refresh screen
F1=Help
F2=edit
F3=Find Next
F7 = Spell Check
F10=Save schedule or comit changes
Shift +F2 = Reorganize now
Shift + F9 = Level Resources
Ctrl-N = New project
Ctrl-O = Open Project
Ctrl-W = Close all projects
Ctrl-P = Print
Ctrl-X = cut
Ctrl-C= Copy
Ctrl-P = Paste
Ctrl-A = Select All
Ctrl-E = Fill down
Ctrl-F = Find
Ctrl-R = Replace
Ctrl-Num + = Expand all
Ctrl-Num - = Collapse all
Rommel Jay Galvez
User offline. Last seen 5 years 26 weeks ago. Offline
Thank you for this.
Samir Gharib
User offline. Last seen 12 years 4 weeks ago. Offline
good approach Alex.
regards
Alex Wong
User offline. Last seen 11 years 47 weeks ago. Offline
Groups: TILOS
A quick way of building a project plan from a list is using import and export function
Normally I copy the list of WBS from the orignal specification, BOQ, Deliverable list, milestone list ...
Fill that in a excel spreadsheet with preliminary dates and resource budget hrs Q $, then import it into my P3e schedule. Once its in then I start to detail each WBS and link them together to create a CPM.
HTH
Alex
Kevin Button
Other than what is listed on Primavera help I have found only 2 other shortcuts/tips.
1. When you have selected a bar that has a + or - symbol, pressing CTRL + TAB will expand or collapse that line. This works on Resources, codes, activity summary lines and other hierarchical structures.
2. While in the Activities screen use CTRL + Roll Mousewheel to scroll one screen at a time.
A D
User offline. Last seen 4 years 14 weeks ago. Offline
In P3 help, check the shortcut keys.
You will find a load of shortcut keys
