_ve float explains delay of project i.e -6d float means project is 6 days behind schedule..You can get -ve float values in P6. Go to columns---->Durations----->Total float
I have assigned about 5000 per week from Jan to December 2007, after that 7000 per week . Thats working and graphs is almost fine and dates are also fine. But I am not getting float . Folat valus are same as before leveling .
If dates are changing then float should be changed.
Check your maximum allocation. It may not enough to cover your resource requirement. This will still show delay on other activities. Also check other resources if has been leveled for those activities that not affected. You can do this separately or per resource and check the difference.
You have to select the resource to level first and add leveling priorities of which activities should level first when conflict accours. Make sure that you also set the maximum quantities of resource available as a boundary for your resource leveling.
Check your critical path and critical activities. Try to compute manually using forward pass (LS-ES) or backward pass (LF-EF) if you will have same result. You might have same float because critical path still the same.
Dear All,
Any body help me regarding the -ve Float
After Updating the Program in P6,we have number of -ve floats, how to check the certain value of -ve Float (For example -33d Float) ???
How to filter the -33d float in P6
Shahajahan
Minhas,
Primavera does not level non labor resources.
Vladimir
Thank you Rodel.
Thannks
Minhas
Minhas,
Hope this help,
Rodel
Dear Rodel,
Thanks for reply.
I have leveled and prioritised everything is calculates but only float is not calculating properly. Only it works on half of the schedule.
Please reply...
Minhas
Minhas,
Hope this help,
Rodel
Minhas,
Hope this help,
Rodel
