Need help installing P5 - very urgent please
6 replies [Last post]
Moutassem Al Kouatli
Dear planner,
i am about installing P5 on my laptop, i tried to install it as standalone, but it keeps asking me for Data base configuration, after accepting the default configuration while installing it, when i first launched it it asked me about a password for the database, i changed and i input it, and then i got a message that it cannot be connected to the database.
has anyone faced this problem, can sombody help please
i am very frustrated
cheers
cheche
User offline. Last seen 10 years 44 weeks ago. Offline
 good day....
 is there anyone there who have a step to step manual for P6....please....we need it urgently....for our delya analysis...
 please email it to cheplan88@gmail.com
 a million thanks if you have one....
 Ricafort,Charito Bobis
  Pitsburge Nitro Asia...
  South Africa.....
Shahzad Ahmad
User offline. Last seen 15 years 36 weeks ago. Offline
I would like share my exprince i face same problem...
insttaled P5 standalone only on window NT it will be work fine.
i am using same one on window NT you can try for same.
actually i have 2 Operating system in my laptop Win XP as well as Wind NT.
you may use the same option.
hope it will be work for you.
Isagani Culaway
User offline. Last seen 12 years 50 weeks ago. Offline
good day,
id rather to use Xp. Can anyone help me to install step by step the P5.
thanks.
Dieter Wambach
User offline. Last seen 7 years 49 weeks ago. Offline
Isagani
P5 doesn’t operate under Vista. You should upgrade to P6.
Isagani Culaway
good day,
is it applicable also for vista to install this primavera 5. i have same problem also with this P5. i dont know how to run this properly.
thanks,
Dieter Wambach
Moutassem
1. Did you check if you have local admin rights on your pc? The check for correct password might be due to database not existing.
2. Was there any error message during the installation of the MSDE Express? E.g. if Framework.net was not installed before SQL-Server, the SQL installation runs through some error messages, instaqllation will be incomplete, but doesn’t stop. Result: This error message. How to solve? Uninstall P5 --> Install Framework (form MS or the P5 Installation CD) --> Install P5.
Good luck!
