Assigning a wbs code to multiple tasks - Urgent reply request
Could someone tell me if there is a simple way of assigning a wbc to multiple tasks - I have to issue a contract programme by the end of the day and I have imported a programme without ant WBS codes in it!!
Andrew
W
waseeq khan 👤 Member for 14 years 11 months
Hi Alexandre,
Thanks it works. You mad my task simpler.
Waseeq
M
Mohammad Aslam 👤 Member for 19 years
Hi Andrew,
Do the following steps
Go to File - Export
Select spreadsheet
Select Activity
Select Template (modify Template)
Select Columns to be exported to excel spreadsheet (Activity ID, Name & WBS code)
Change WBS code in WBS columns or copy paste (in Excel spreadsheet) the WBS code of activities in the same WBS element.
Make the changes, save the spreadshhet.
Import the same excel file into the project.
it's done
Hope this help.
Mohammed Aslam
Alexandre Faulx-Briole 👤 Member for 23 years 5 months
Hello Andrew,
I don't know how many tasks you have to assgn; it is possible to drag and drop the tasks inside a specific WBS node: place the mouse pointer on the left of the task name until it becomes a small page, push down the left mouse button and drag the task until it comes under the said wbs node.
it is fast and easy; at least when you not have thousands of tasks!
Alexandre
Saqib Ullah
Luyanda Ndlumbini
Jeff Waldrop
Robert Roy
Tony Wright
Arshman
Stan Remiszewski
GeoVe
JAGAN REDDY MUSUKU
