How to filter out only those activities driving a task?
Arthur Godbeer 👤 Member for 19 years 11 months
There is another existing enhancement request to show which relationships are driving, as a column.
I know this is not what you’re asking, but in case you don’t know, you can show (with a tick) which activities are driving, within the Predecessors or Relationships/Predecessors tabs.
To show driving relationships only in a layout is an existing enhancement request, according to the Primavera Knowledgebase.
David Podmore 👤 Member for 20 years 2 months
Thanks for that Alex.
It’s not the simple answer I was hoping for! Ah well, I guess we will have to wait for Primavera to add it as a function.
Trace Logic is the closest we have found to an answer but it’s still not as good as "Display driving links only" in Pertmaster.
Again, thanks for your time.
David
Alex Wong 👤 Member for 23 years 4 months
David
to do that you need the un progress baseline schedule
What I normally do is since some of the activity is already completed and finish so it is very hard to filter and trace all the activity which is linked to this particular activity,
to filter that first step is use the baseline schedule (With the same logic sequence) (make a copy) - add a finish no later constraint in the tail activity with a very very early day 2 year before its early finish day or something like that
Schedule the plan
Filter the activity with excessive negative float,
Remove the constraint
Schedule the plan again
Then you will have all the activity that have assoication (link) with this activity
Sort the activity by total float
the lease float activities are the critical path for that particular activity, and the rest is on the critical path but not necessary as the critical activity
HTH
ALex
Erkan Polater
Soheil Barekat
Luis Jr Ngade
Ben Welsher
Rohan Dashputre
AMECHI ANAKWENZE
Jayaprakash Sekar
arash.karmand
Vahidazimi01
