SQL - How Can I Select Only Critical Tasks
C Molland
User offline. Last seen 10 years 4 hours ago. Offline
Hello
I am developing an application which pulls data from a P6 SQL database. I want to select all Critical Tasks. Can someone advise me which SQL database Tables/Fields signify a Task as being Critical please.
I thought there was a 'critical_flag' field in the TASK Table but on checking I don't have one.
Thank you.
Barrie Callender
User offline. Last seen 2 years 1 week ago. Offline
Sorry I got trigger happy and ended up posting the same thing twice
Barrie Callender
The Total Float is held in the TOTAL_FLOAT_HR_CNT column in the TASK table.  You can look in the PROJECT table to find out what has been configured for Total Float and your SQL can be written to identify the Critical Tasks.
If you are using SQL directly then be careful to exclude the deleted Task records.
User offline. Last seen 27 weeks 4 days ago. Offline
I still think that this wil get you what you want
C Molland
Thanks for the suggestion. I believe that this would be used only if the critical tasks were calculated using 'Longest Path'. In our scenario critical activities are calculated based upon total float.
try
driving_path_flag
