Duration calculation by calendar
Dave Dodds 👤 Member for 19 years 11 months
M
MK TSE 👤 Member for 24 years 4 months
sorry to let us know, no change in P6. the "duration" is determined by user perference within the "calculated dates" by defined calendar.
Which means the display value in duration is keep on changing if user preference is changed.
David Kelly 👤 Member for 21 years 8 months
Version 5 is the same. No "rumors" that version 6 will be any different BUT will probably allow a work-around.
Dave,
Thanks, I just discussed this with our admin. It does pose a problem to our field plans that do not work 1-8-5. The default for our database has to be 1-8-5 for mfg. Do you know if version 5 has address this?
BTW, 3-1 would have been easy with Utd. It is going to be a tough season as an arab.
Alex,
1-8-5 is 1 shift, 8 hours, 5 days. Therefore 2-10-7 is 2 shifts, 10 hours, 7 days. I don’t know if this is just Canadian terminology, but it makes sense to me.
Cheers and Thanks for the help.
Dave
Let me guess.
You changed all the activity’s calandars, but mysteriously all the durations for the summary bars have stayed the same?
In P3e all summary durations are calculated as the number of working periods between the start and finish of the summary bar as measured on the database’s default calandar. The default calandar is "ticked in the global calandar display.
Alex Wong 👤 Member for 23 years 4 months
Dave
1 8 5 ??
1:oo - 8:00 5 days??
or
1 Days 8:00 - 5:00
or
1 shift, 8 hrs days and 5 days??
Please clarify
Alex
Erkan Polater
Soheil Barekat
Luis Jr Ngade
Ben Welsher
Rohan Dashputre
AMECHI ANAKWENZE
Jayaprakash Sekar
arash.karmand
Vahidazimi01
