Error importing P3 to P3e.
Marcio Sampaio
User offline. Last seen 11 years 50 weeks ago. Offline
Dear all;
I don’t have P3 installed on my PC. I’m trying to import a P3 file but P3e shows this massage:
"Unknown error reported by P3 engine"
Do anyone knows why is it happening??
Regards.
Marcio Sampaio
Hello all;
Read this reply.
Regards.
Check that the btrieve home directory is set OK.
It is possible that the default installation has set the btrieve home value to a directory where you do not have rights to create a file. The import then fails because the trace file cannot be opened.
There should be a utility on your PC called w32mkset which can be usedc to view and set the btrieve options.
Other than that I have seen this problem where the P3 files have a link to a graphic file that does not exist and where access rights are incorrectly set.
Good Luck
Marcio Sampaio
Thanks Christian ... i’ll provide a license of P3 with brazilian partner of Primavera.
Christian Adrian ...
User offline. Last seen 5 years 3 weeks ago. Offline
Hello Marcio
you need to have a P3 installed as well. When converting, P3ec will be prompting you to type the username and password in P3 before you can access those files.
HTH
Christian
Marcio Sampaio
I have already tried P3toP3econvert.exe but didn’t work.
Same error.
