Logic errors after Updating from an XER Import
Mike Thornley
User offline. Last seen 15 years 4 days ago. Offline
I have found that after importing an XER file to Update an existing Project some logic changes occur. These have lead to loops, which hightlighted the problem otherwise I may never have discovered the logic changes.
Has anyone else found this happening? Do you know what causes the problem? How do I avoid it happening?
The only way I can trust an import is to replace the existing project but then I loose the filters on Project Codes.
Kevin Button
User offline. Last seen 3 years 16 weeks ago. Offline
Mike
It might be worth checking your Import Configuration Options. The online help on this area suggests that for the Activity Type data you need to select the ’Update Existing’ action and tick the Delete box. Unless I am mistaken this should remove any existing relationships and replace them with those in the xer file being imported.
Mike Thornley
P3e version 4
Bill Guthrie
User offline. Last seen 8 years 48 weeks ago. Offline
what program are you using
bill
