Summary or Filter
James bid
User offline. Last seen 10 years 10 weeks ago. Offline
Hi Guys!
If I want to view the summary of certain level.. Example the summary of Level 3 construction. should I go to Format\ Summarize all? or Filter, if in Filter How can I do it?
I tried this thing (format\Summarize all)but still all the levels was shown. I need only the level 3 summary.
thank you and Good day
Chris
James bid
Good day Shahul!
I cannot get.
Still Engineering and procurementn showed in the summary. I need only the Construction.
Can u give me step by step?
Thank you
Shah. HB
User offline. Last seen 50 weeks 1 day ago. Offline
you could do for level 3 the same format summarize option but select the respective levels
Shah. HB
1.Better you could go for filter option to list out group of construction activities under construction WBS
2.Have you build your WBS using WBS option or activity codes option?
