Formatting Summary Bars
12 replies [Last post]
Hemanth Kumar
User offline. Last seen 1 year 32 weeks ago. Offline
Dear Friends
is it possible to give another colur to the summary bars (sub total bars)
Alex Wong
User offline. Last seen 11 years 45 weeks ago. Offline
Groups: TILOS
Or as Philip suggested using hammocks is your only way out
However, it involved a lots of work
Good luck
Alex
Sen Moc
User offline. Last seen 19 years 5 weeks ago. Offline
Kumar,
Create dummy activity codes (or use your existing codes).
Then choose whatever color you prefer in Format Bars/Pattern.
This is the only way your problem will be solved!
Sen
Alex Wong
Groups: TILOS
Cannot unless you are using P3e teamplay or P3e/c
Hemanth Kumar
Not Possible
,,,thanks to all
Philip Jonker
User offline. Last seen 16 years 9 weeks ago. Offline
You have lost it
Hemanth Kumar
Not Possible ,Pattern Will Give Color to coded activities
Only
Shahzad Munawar
User offline. Last seen 9 years 40 weeks ago. Offline
Not possible so far
Sen Moc
Question:
Is it possible to give another colur to the summary bars (sub total bars)?(/i>
Answer:
YES. Go to Format Bars/Pattern.
Cheers!
Sen
Hemanth Kumar
hammock cant show real summarised % complete
Philip Jonker
Then try using hammocks, which you can format
Hemanth Kumar
dear peter
you cant format summarised bars
Peter Bailey
User offline. Last seen 19 years 4 weeks ago. Offline
Try ’format - bars’ and then change the colours as you like them
